vinced
#1 Posted : Tuesday, August 30, 2011 12:31:34 PM(UTC)
vinced
Folks
Whenever I import a DWG file the text in the drawing looks either way to huge or microscopic. I don't have these issues when I open the same drawings up in AutoCad 2010, CorelCad or TurboCad. I am using Mac v8 2D/3D
PS We already have 7 copies of ViaCad 2D/3D in our engineering and Production departments. but would also like to get 5 more copies for Customer Service, but this issue is a show stopper, any a dice would be helpful
Vince
#2 Posted : Tuesday, August 30, 2011 1:18:28 PM(UTC)
same used to happen to me on earlier build, but Tim fix on shark fx bild 968
There is a thread for this issue:
http://forum.punchcad.com/showthread.php?t=3855
Luis G.
MacOSX 10.10, Yosemite
Shark FX V8, Beta testing Shark FX V9-1146
vinced
#3 Posted : Tuesday, August 30, 2011 1:47:30 PM(UTC)
vinced
Luis
Actually (correct me if I am wrong), your issue was opening a file in AutoCad. My issue is with opening a DWG in ViaCad 2D/3D v8. Drawings look fine in every other DWG compatible app (AutoCad 2010, CorelCad or TurboCad) we have, except for ViaCad.
#4 Posted : Tuesday, August 30, 2011 5:16:14 PM(UTC)
My mistake, i didn't get your point at the beginning, and yes, that topic i mention is referred to a file exported from shark and opened in autocad.
Regarding your issue, i think is more related to the file, does this happens to you on different files?, cause import dwgs files many times, and some times flawlessly and some times with several errors, and sometimes i give up cause could not be imported.
Luis G.
#5 Posted : Wednesday, August 31, 2011 9:04:32 PM(UTC)
Was thanked: 151 time(s) in 96 post(s)
Hi Vinced,
Can you confirm it's a unit conversions inches to mm?
Scale factor 25.4, or 1/25.4
Frequent issue...
JL
vinced
#6 Posted : Thursday, September 8, 2011 12:10:51 PM(UTC)
vinced
JL
I am not totally sure what you want me to check. The Original drawing was non-metric.
#7 Posted : Thursday, September 8, 2011 1:07:33 PM(UTC)
Vince
Can you send me an example file? I will check into. Also let me know what build of ViaCAD you have.
If possible, zip and send to me at [email protected].
#8 Posted : Friday, September 9, 2011 11:31:08 AM(UTC)
Fixed in 991.
