dudko
#1 Posted : Sunday, May 17, 2009 9:56:27 AM(UTC)
dudko
Bug or not ???
Text along curve example:
arc drawn in XY, letters aligned in the Z,
letters do not have the same distance??
Best regards Ed
dudko attached the following image(s):
#2 Posted : Sunday, May 17, 2009 10:28:04 AM(UTC)
Originally Posted by: dudko Go to Quoted Post
Bug or not ???
Best regards Ed
Hi Ed
When you check the text in the object info box is the screen horizontal box checked? What happens if you uncheck it.
Also noticed that you cannot change the direction of a 2 point arc. All other arc change direction which effect where the text along curve starts.
dudko
#3 Posted : Monday, May 18, 2009 3:55:42 AM(UTC)
dudko
JDI000 senks for answer,
if the screen horizontal box checked, it`s working, but there`s too much space between the letters.
Problem found:)
Command "Text along curve" depends on view.
See results (pict.)
Arc drawn in topview
Text aligned in frontview,reightview and dynview!!!!
dudko
#4 Posted : Tuesday, May 19, 2009 11:30:58 AM(UTC)
dudko
Other problems
Objectcolor behind text will be ignored
TfS.vcp (13kb) downloaded 5 time(s).
dudko
#5 Posted : Tuesday, May 19, 2009 11:53:00 AM(UTC)
dudko
Other problems
Convert text to curves, result is bad
