Tem
#1 Posted : Friday, August 1, 2008 1:50:45 AM(UTC)
Tem
I have been getting really bad export meshes from OBJ export from sharkfx. I did get an acceptable mesh exporting STL. The OBJ mesh had problems along rounds, especially edges that had compound curvature. The file was translated from a step file and then into an OBJ mesh.
Maybe a mesh should be created within SharkFX first then exported as OBJ?
Thanks all!
Tem
#2 Posted : Friday, August 1, 2008 9:43:35 AM(UTC)
Thanks all!
Tem
Hi Tem
The OBJ exporter uses the display list facets. You can use different resolutions to increase/decrease facets. For more control, you can change object type to a mesh providing access to the facet parameters.
