Suggestions
Importing files on other core? (#511)
While I sit here staring at my LCD waiting for a large part to import, I just realized how much better CU would be if it could import files as a background task by utilizing one of my other processors or processor cores? If rendering can be multicore, then why not part importing? This importing would be done into a new file, not one that I am currently working on. This would increase my productivity quite a bit. Thanks to Tim & Crew! Tem
form z has a great feature where you can copy the whole application folder and run multiple version of the application at the same time. So, rendering or performing a time consuming function on one app, just switch to the other a and continue working on another file. Gary
Is this an option Tim .. to run multiple instances of CU ?
Fully agree with Tem.
I have 7 lazy cores sleeping at home !
And no Snow-white to sing with the birds.
JL
(22kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Suggestions
