Tim & Crew,
Please, look at this technology:
http://www.tsplines.com/t-tools/ I would love to make use of it In CU5, or sooner.
Thanks!
Tem
Not quite sure what this does but I do know our splines need some lovin' take a look at illustrator, solidworks and so on splines look lovely .. and what's more .. and here's the thing .. on a complex spline, you can get EXACTLY the curvature you want much more easily
You have been a member since:: 2/18/2007(UTC)
Thanks: 235 times Was thanked: 184 time(s) in 111 post(s)
Tem wrote: look at this technology
It seems to be a good tool to manage nurbs curvatures and tangencies.
JL
to make good solids - you need good surfaces .. and for good surfaces you need good splines Please can we have better splines Please have a good long look at Illustrator, Pages, Cheetah and so on
Drawing splines in Pages and in Keynotes is very nice & easy.
By the way, I threw away my Freebox modem, and I'm back able to upload files to this forum.
JL
(30kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Looks like there are plugins available only for Rhino and Maya. Everything else out there to date is either NURBS or subdivision/facet. tom
Thanks: 6 times Was thanked: 29 time(s) in 16 post(s)
Please try to incorporate this! It looks as this will be the solving of all tangency-dependent modeling problems we have now!
Would really love to see this! (assuming it works as they claim!)
ALBAN
This seems to be a real winner, especially regarding conceptual design/3D "sketching". It would also solve a lot of file translation problems, as t-spline surfaces can be seemlessly converted into spline surfaces as well as sub-D surfaces (at least that's what they claim). If they can live up to how they're describing the technique, this will become a major step in the development of CAD software. Ciao, Norbert
Thanks: 28 times Was thanked: 16 time(s) in 5 post(s)
Ill second that motion, looks very promising. Has anyone used the plug-in in either rhino or maya?
Very interesting abilities Whilst we undoubtedly need pushy-pully surface capabilities .. .. My concern would be can you use 'T Splines' to make something that doesn't look like a peice of used soap ? .. ie with tight surface control !?
jol wrote: Very interesting abilities Whilst we undoubtedly need pushy-pully surface capabilities .. .. My concern would be can you use 'T Splines' to make something that doesn't look like a peice of used soap ? .. ie with tight surface control !?
If i understand it right you can transform any set of Nurbs surfaces into T-Spline surfaces! In the worst case one would start with a rough set of nurbs definitions and transform it into T-spline to modify the entire shape at once....
ALBAN
As I understand, the 2 splines are sharing the same normal at crossing point. This could only help smoothing Jol's soap. Am I wrong ? JL
jlm wrote: As I understand, the 2 splines are sharing the same normal at crossing point. This could only help smoothing Jol's soap. Am I wrong ? JL
Not sure about this! I dont want to defend a technology I dont really know. But you can have creases with control and it seems possible to translate tspline surfaces into nurbs and vice versa without loss of information.
Maybe I got it wrong?!?!
Is there someone out there using Rhino besids Concepts? There is a 14day trial plugin for Rhino.......please test it!!!!! :)
ALBAN
From using Rhino I can say that there was a way to "weight" nodes/points on a NURBS surface. This allowed me to loosen/tighten inter-surface transitions, uhmm...make the surface smoother / bulge less, or more. In this way the SOAP effect could be reduced. However that was all for NURBs surfaces. I do not know if T-Splines have this capability. I know that with polygon modeling there is a way to control how soapy ones model is too. The maths are out there, too far out there...
