Import/Export
Can't extrude a 2D imported Adobe Illustrator (#3931)
                .ai file image (also a photoshop file had the same problems). In Shark I can't resize the z axis and I can't use the extrude tool on the z axis to give it a 3rd Dimension. Not sure if there is some conversion into some kind of compatible object that is necessary or what? I can create a square at top and go to front and use the extrude tool (vector and distance I tried).
thepopoman attached the following image(s):
(63kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                How you played with the import options?  I'm in sharkFX 968.
                Well I didn't understand them all but for Illustrator i checked all 3 import options and imported and later just the middle one and imported.
                Maybe post part of the file.  I checked my last job and I have everything unchecked.  I do recall importing custom text and extruding the sucker.  The letters imported as groups.
                Ok thanks.
                You aren't try to extrude that from a photograph (.bmp, .jpg, etc), by any chance are you?
                Well I tried extruding from an Illustrator .ai file (CS5) imported which is not a bitmap raster image (a vector). I tried exporting to photoshop from Illustrator and importing into Shark and also I tried exporting to PDF in illustrator and importing to Shark.
                It would be good if you could post the file here for us to look at.
                I created 4 views with all gripper options check marked ... but not sure if that's saved in the file or not.
Can't non-universally size it on the Z axis or use the extrude tool to extrude it on the z axis. Right now it's at least scaling up/down on the x and y axis but no z axis.
By the way if you want to scale on two out of the 3 axis at the same time... how do you do that with the gripper?  Or do you have to use a different tool?
   Dave
When I import is that linked or embedded?
 ThePopoManImportedFromIllustrator.sfx
(166kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                I sent an attachment .sfx Shark file but I wasn't sure if the file I imported in it was embedded or not. So I tried to send another post with both files but the attachment manager seems to only let me attach one file at a time in a post. So not sure if people can see the .ai file or not.
                It won't extrude because it is a picture, not a vector.
Martin.
(63kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
                Well that makes sense. However I'm not sure how an illustrator file becomes a picture without you explicitly exporting it into one.  Hmmmm.
                I'm not sure I understand how an illustrator .ai file would NOT be a vector file.
                change the extension to .ps for postcript.  I recall someone changing the .ai extension to .ps.  However, they just added it after .ai.  Not sure if that really matters.
                I used a simple square in illustrator and was ABLE to extrude it by exporting/importing it as a DWG/DFX format. But the gripper axis's were not working the directions I expected. I expected since the object appears at the top view in 2d that the z axis would be the 3rd dimension to extend/extrude it... however it seemed the color coded x axis was the axis from the gripper that worked. X Y and Z might be different in the standard CAD DFX/DWG formats or something like that.
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
