Mac CU v4 Candidate Release (#4)
Hi All, You are welcome to try the Mac CU v4 candidate release installer. This will install into a new folder, perserving the older SP2 folder. This build is 660. If you have a registered version of v4, this will behave as a fully functional commericial version. Regards Tim Olson Punch! Software
Tim: The link posted here for downloading UB v4 SP3 seems to be broken.The requested URL /Demo/v4/CUv4sp3.dmg was not found on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request .
Brian Graham Mac OS Ventura 13.6.3 Mac mini Apple M1 16GB 1TB SSD Shark FXv 14 Build 1641
We're uploading another build. Tim Olson Punch! Software
admin wrote: We're uploading another build. Tim Olson Punch! Software
Are we there yet? Thanks.
Yup, try the link above again. This will download Mac build 660. Tim Olson Punch! Software
Thanks, Tim. I'll let you know how this one goes.
I had v4 SP3 installed but thought I should re-install with the latest. Install goes fine but CU won't boot. I all ready threw away entire v4 folder and installed but that didn't work. I need to get up and running soon. Ideas? Patrick
Still can't get v4 SP3 to run. Anybody else having this problem? Patrick
There is apparently an issue with a small part of the new release not being 'universal' Try setting the "use rosetta" tag and it will launch.
You're right. But when it booted it went to the Activate Screen. I didn't want to activate it in case it de-activated the SP2. Any info on how this all works and when the universal build will be out?
HI All, Please download again. One of the libraries was incorrect for Intel macs. Tim Olson Punch! Software
This works but now my software won't authorize. Do we need new codes? I copy and pasted the codes from an old email and that didn't work either.
>>Do we need new codes? I copy and pasted the codes from an old email and that didn't work either. No, the codes did not change. Serial Number info is store outside the app folder. On mac it is Library/Application Support/CSI/Concepts Unlimited/CURegInfo.ini If you are using a trial serial, the app displays the registration dialog box each launch now. Try entering your serial number/registration key and hitting register key. erase the auth code field. Tim Olson Punch! Software
There's a Symbols installer as well. Does this install anything new or are we better off dragging from one folder to another? Patrick
Hi Tim Olson Is it possible to just download Concepts2D build 660? I only have serial number/registration key for Concepts2D. (Concepts2D imports FormZ perfect :)) /Peter Boldsen Mac OSX 10.4.8 (Intel&PowerPCG5)
Thanks: 26 times Was thanked: 6 time(s) in 3 post(s)
used the link on page 1 and downloaded again. It is the same link as we used for build 660? This is still build 660? The creation date for CU is exactly the same as it was before: 22.02.07. Is this correct? Does this mean the only difference is something getting installed in user "library" and all else is still the same?
>Does this install anything new or are we better off dragging from one folder to another? The symbols installer has not changed. Reinstall from the original dmg or save and drag back.
The Mac 660 build was updated early morning. All library issues and polar duplicate crash are fixed. You can download CU, C3D, or C2D from the demo links. We should have an official announcement shortly.
I must be blind. Where did the links go? Patrick
I removed the direct links from the forum because I change them with each build. I was concerned folks would download the older build.
For the current CU service pack, download from the demo page.
http://www.csi-concepts.com/demoDownload.htm Tim Olson IMSI Design/Encore
