2 Pages<12
Art
#21 Posted : Wednesday, July 2, 2008 7:38:59 AM(UTC)
Art
Perhaps in addition to the sweep we could have a way to make construction lines that snap to the standard alignment angles? Perhaps sweep with "command option" and have the line pivot from the origin?
Art
Macintel shark fx
#22 Posted : Wednesday, July 2, 2008 10:25:29 AM(UTC)
Art
Macintel shark fx
Art,
Do you mean temporarily add in more snap alignment angles while in the construction line tool?
Currently the default alignment angles are +-0,90 and creation angle is +-45.
Art
#23 Posted : Wednesday, July 2, 2008 12:52:04 PM(UTC)
Art
That would be great, some way to easily make construction lines snapping to every 15 or so.
While we are on this topic, I would like construction lines to extend to infinity. I frequently zoom in to find just the right point for a construction line and then have to sweep it again and again as I move out to a normal view. Is this something that bugs other users?
Art
Macintel Shark FX
ttrw
#24 Posted : Wednesday, July 2, 2008 4:27:28 PM(UTC)
ttrw
In SW's, construction lines are created by arbitrarily drawing a construction line, then using smart dimension to input the angle that the construction line is at an angle too (if you get what I mean?). So instead of having a snap, you can just for example enter 28 or 36 or 23.7 etc etc.
Snapping in Macdraft on the other hand, uses a series of predetermined angles of which are similar to what has been suggested here. QCad, I draw a line, and then add a line at a predetermined length, and at a predetermined angle to that line.
I don't really know what is better? (I suppose it's a matter of experience, something I could definitely get more of!). However I do like the suggestion of a construction line that goes off to infinity, because I too am always having to lengthen these lines too. I suppose there could be a way of shortening the length of the line later, by using the scissors tool or something? Incidentally, if you take a line off a construction line in SW's you get a proper line, rather than another construction line.
Guest (11)
2 Pages<12
