PunchCAD Technical Support (#4040)
FYI If you are in a bind and need an answer right away, you can contact PunchCAD technical support. The technical support number is: 1-800-856-9601 Tim
Hello, I have been running ViaCAD Pro v8 on my Windows Vista OS for a couple of months now and until this week it has run fine. Now it takes approximately 40 minute to start up. After I exit, I have to go to task manager and end the process manually. Also, it is not saving my preferences. I uninstalled the program, and reinstalled, but nothing changed. Is there an e-mail for tech support? Please let me know what I can do to fix these issues. Thanks, Michael Tuttle
Originally Posted by: Michael Tuttle Please let me know what I can do to fix these issues.
install a working OS as e.g. W7 :eek: (check Amazon/eBay for cheap OEM/SystemBuilder lics.)
if launching VC lasts 40 mins. there's something totally broken with your system. For evaluation purposes you may try to disable/uninstall your security suite or launch Windows to 'safe mode' by hitting F8 during system startup.
hth,
Norbert
Thanks Posh. Funny thing though, I uninstalled Pro v8 and re-installed Pro v7 and it works fine. Mike
