thomasbricker@me.com
#1 Posted : Thursday, January 8, 2009 5:17:49 AM(UTC)
(I am brand new to ViaCad)
Can you add vertexes to a smart polygon or can you only modify single curved lines or straight lines?
Can you change a single line box into a smart polygon?
#2 Posted : Friday, January 9, 2009 5:21:53 AM(UTC)
Not possible?
unique
#3 Posted : Saturday, January 10, 2009 8:11:49 PM(UTC)
unique
Hi Thomas,
To my knowledge you cannot add points to a smart polygon, you can segment individual lines tho or indeed make control point curves and then add points at certain places. Can you elaborate a little what you need to do so somebody can help....
You can use the "join curve" option to join glue the ends of lines together but not as a polygon entity, instead it will be a polyline.
HTH
