Changing MtoS template in VC (#4403)
                Guys, how do I edit and save the MtoS templates, so for example it doesn't read all measuments in inches? Taylor them to my on specifications? Many thanks.  Tom
                Hi Tom You can create a new file for mts and save it in the folder that stores model to sheet templates. So you can build a metric file drag a border and title block in from the symbols Ungroup and modify as needed  Create empty single draw views and modify as required. Whatever settings for each view scale size etc  Save the file in the folder and it will show up in the mts drop down to select. Regards  Jason
                Thanks Jason. The extension name too? Do I same as a vc3 file as normal, and then change the extension name back to vcp manually? I'll have a try. Tom
