TeraVolt
#1 Posted : Tuesday, June 18, 2013 4:58:35 AM(UTC)
TeraVolt
Hello,
is it possible to delet a single tool and rearrange the tool-icons in a user defined tool palette?
Found no solution by myself and nothing in the documentation about that.
Harald
Jean-Francois Jacques
#2 Posted : Tuesday, June 18, 2013 8:33:25 AM(UTC)
Canada
The Row and Column of the Custom Tools Palette cannot be edited (after the first time). You can just replace tool by an other (Right click on the new tool - Drag and Drop on the tool you want to replace). Also you cannot reorder the tools.
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
TeraVolt
#3 Posted : Tuesday, June 18, 2013 10:08:06 AM(UTC)
TeraVolt
Hello Jean-Francois,
thank you, that works fine.
Not exact what I want, but better then nothing. Maybe in a later build there will be a easier from of "editing" *hoping* :rolleyes: should be a 30 second work for a good programmer.
Harald
rokoko
#4 Posted : Friday, October 4, 2013 1:42:00 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
hi, i detected that custom tool palettes can be edited afterwards by a right-click inside the custom tools area of the palette
#5 Posted : Friday, October 4, 2013 2:21:34 PM(UTC)
Canada
Yes, its right! I found it some times after my previous message.
TeraVolt
#6 Posted : Sunday, October 6, 2013 7:51:49 AM(UTC)
TeraVolt
with right-click on the customs tool palette you only can edit quantities of rows and columns and the size of icons, but not edit the icons itself.
