Stevecim
#1 Posted : Wednesday, April 17, 2013 4:56:27 AM(UTC)
Stevecim
Hi All
Is there anyway to edit STL model in ViaCAD Pro? I can import, scale, move and rotate triangle that make up the STL model, but I cant seem to delete any of the triangles?
Cheers, Steve
#2 Posted : Wednesday, April 17, 2013 7:41:23 PM(UTC)
Mexico
working with meshes in shark-viacad is painful, not recommendable, at least I think so
there is no specifict tools to handle meshes on vicad, you can try to convert to faces, edith them and then convert to meshes again but, believe me, is frustrating,
is better to use a polygonal software as blender, cinema 4d or modo to do this.
Luis G.
MacOSX Sequoia 15.7.7
zumer
#3 Posted : Thursday, April 18, 2013 7:31:59 AM(UTC)
zumer
The way each triangle meets the triangles along its sides is part of the .stl format. Adjacent triangles must share two vertices, a full edge, so deleting a triangle from an .stl is one of the easiest methods of making it non-compliant with the format. You can replace coplanar triangles with planar polygons, but that makes it not an .stl file. Posting a specific example will make it easier to help.
posh.de
#4 Posted : Thursday, April 18, 2013 7:56:33 AM(UTC)
posh.de
you may want check the free [URL="http://www.meshlab.org/"]MeshLab[/URL] and [URL="http://www.netfabb.com/basic.php"]netfabb Studio Basic[/URL] for editing and formatting STLs before evaluating a full blown mesh modeler.
hth,
Norbert
