ColdMuffookies
#1 Posted : Tuesday, September 6, 2011 10:46:51 PM(UTC)
ColdMuffookies
Alright I know there is a model to sheet function but is there a sheet to model?
Along the same lines when I could not foresee a solution I made a general profile of my project and figured I could just use the lathe tool however I get an error saying that there are over lapping curves. I verified that there are none so what am I doing wrong.
#2 Posted : Tuesday, September 6, 2011 11:01:10 PM(UTC)
first question - no
second question - can you post the profile you are attempting to lathe please
ColdMuffookies
#3 Posted : Wednesday, September 7, 2011 1:51:13 AM(UTC)
ColdMuffookies
Not a problem thank you for your quick reply I supplied the partial sheet minus dimensions and the outline for the lathe
project1.vc3 (51kb) downloaded 0 time(s).
project2.vc3 (145kb) downloaded 0 time(s).
#4 Posted : Wednesday, September 7, 2011 2:12:36 AM(UTC)
On your profile
there is an unwanted
element - a 'control point spline' ... which has zero length
(Tim perhaps you could look at why this is possible - and why the reporting of this spline in not very helpful)
If you fence-select (left to right)
across this exact corner (shown),
you will see that the edit object window reports
'3' elements in it's top bar - instead of the 2 you would expect.
If you delete the extra element, you can then
make a nice lathed object
Hope that helps
ColdMuffookies
#5 Posted : Wednesday, September 7, 2011 5:20:39 AM(UTC)
ColdMuffookies
Thank you very much now I can continue on with the build. Your help is much appreciated.
#6 Posted : Wednesday, September 7, 2011 1:22:06 PM(UTC)
I modified the lathe, extrude (all profile based solids) to ignore zero length curves in the next build 990.
#7 Posted : Wednesday, September 7, 2011 1:23:08 PM(UTC)
Did you import the profiles using another file format? If so which format did you use?
Thanks!
#8 Posted : Wednesday, September 7, 2011 3:04:50 PM(UTC)
To paraphrase Caprica 6: "We have GOT to clone your brain patterns", but we've GOT to clone Tim. Imagine if there were 6 or 7 of him working like Data when he moved his fingers along the console at near-light speeds, hehehe
zumer
#9 Posted : Thursday, September 8, 2011 4:49:30 AM(UTC)
zumer
Sorry, ZLC. Tim is ignoring you in build 990!
Guest (10)
