This happens form time to time. This view is a bottom view of a part. Yes the numbers are correct if viewed from the other side of the monitor.
David
MBP 2.33 core2duo 10.5.8 Shark LT build 853
sporeleki attached the following image(s):
(47kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi David
Can you private email me the file as in the image?
tim.olson@punchsoftware.com Tim Olson IMSI Design/Encore
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
This happen to me on MacOS once when i "pull" a new drawing view from other viewport than the front view, seems like that is interpreted as a "backview" viewport, so the text it is inverted. Luis G.
This did happen on a view that I pulled from another view. Perhaps it is better to create a new view window/box, then assign the view. thanks Luis
Thanks: 199 times Was thanked: 164 time(s) in 113 post(s)
This is still happening with SharkFX7 SP1 959 on Win7 32. A Bottom will show dimensions upside down. I have been rotating the Top view 180 degrees, but that is just not right. Please take a look. Larry
