sporeleki
#1 Posted : Monday, July 12, 2010 11:59:19 AM(UTC)
sporeleki
This happens form time to time. This view is a bottom view of a part. Yes the numbers are correct if viewed from the other side of the monitor.
David
MBP 2.33 core2duo 10.5.8 Shark LT build 853
sporeleki attached the following image(s):
#2 Posted : Monday, July 12, 2010 2:07:02 PM(UTC)
Hi David
Can you private email me the file as in the image?
tim.olson@punchsoftware.com
#3 Posted : Friday, July 30, 2010 7:20:18 PM(UTC)
Mexico
This happen to me on MacOS once when i "pull" a new drawing view from other viewport than the front view, seems like that is interpreted as a "backview" viewport, so the text it is inverted.
Luis G.
MacOSX Sequoia 15.7.7
sporeleki
#4 Posted : Monday, August 2, 2010 3:42:04 PM(UTC)
sporeleki
This did happen on a view that I pulled from another view. Perhaps it is better to create a new view window/box, then assign the view.
thanks Luis
L. Banasky
#5 Posted : Sunday, January 23, 2011 11:25:23 AM(UTC)
L. Banasky
This is still happening with SharkFX7 SP1 959 on Win7 32. A Bottom will show dimensions upside down. I have been rotating the Top view 180 degrees, but that is just not right.
Please take a look.
