Snap to toroid (#2615)
                I've drawn a toroid shape (bicycle tire) and want to snap to it, at the point it meets the ground.  There don't seem to be any snap points for this 3D part.  How do I turn them on?
                Hi CFB. Welcome to the forum :)
You probably need to draw it differently to how you were anticipating the procedure to work (VC/ Shark doesn't work like most other CAD apps).
So;
Start by setting the view to 'front'. Draw your axis like (any length), then measure a line that is based on the radius of your tyre's size, then draw another circle set at the radius of your tyre's thickness.
Then change your view to right view, and draw a line on the tangent of the circle (ground)
Switch to isometric view, and using the lathe tool, select your circle, then your axis, then you should have this;
There may be another way, I'm sure someone else will interject if that is the case :D
Tom
(125kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                You can also highlight the part, and go to Menu: Verify > Bounding Box, around the Toroid, and use the edges to help you put construction lines where you need them for suitable intersections, as in the attached pic.
Martin.
(49kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: ttrw  (VC/ Shark doesn't work like most other CAD apps).
You can say that again :D:D
                Hi Martin,
    Ian Kirby
                Also, you can "Change Object Type" in the edit menu, and change the object to a mesh. That also works.
(120kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Originally Posted by: ttrw  Also, you can "Change Object Type" in the edit menu, and change the object to a mesh. That also works.
Hi Tom,
Changing the object to a mesh is not a good idea when it is intended for snapping, as where the intersections of the polygons of the mesh are created is not controllable.
Hi CFB
Probably the easiest way to create snapping positions is to create ISO curves then explode them: see pic (it as also been mentioned in another thread for use with creating paths). Some caution is needed on shapes like this when selecting what to explode, as VC/Shark rebuilds the surfaces as you rotate, so there is an hidden seam/edge (well, not hidden very well) that can be selected and give what would appear strange output (There is a link to a vid to show this)
Hidden edges; explode: Download link - Steve
(139kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Thank you Blowlamp.  The bounding box trick was nice and simple and did the trick, for me.
                Hi Colin,
                Originally Posted by: CFB
Colin, the reason you can't open an AVI file, is because you haven't set you computer up correctly. If you nip over to the Apple website, you will find the appropriate plugin in the QuickTime section.
I have a Mac too, and have no problem reading AVI files. :)
regards,
Tom F.
                Hi Steve,
                Hi Colin,
Originally Posted by: CFB  Thanks for the step by step with images.
Your Welcome
You would probably be better to send Tim an e-mail (
tim.olson@punchsoftware.com  ) for the latest build.
- Steve
                Originally Posted by: ianjkirby  Hi Martin,
Ian.
If I understand you correctly, just rotate the view to your liking and set the workplane to Use View and enter your text in the normal way, altering size and colour etc as required. Alternatively, you can add text to a screen grab in Paint, if you use Windows. Let me know if that doesn't cover it for you.
I'm no great beta tester myself, but it's sometimes surprising how mundane actions can uncover the gremlins, and I think we've both found the odd rough edge that's needed a bit of work in VC. It's nice that others contribute and benefit from the improvements too.
Martin.
                Originally Posted by: CFB  Hi Steve,
Colin.
Whilst the Bounding Box method isn't as elegant as Steve's, it does work ok for me - did you have Endpoint Snap enabled or perhaps it's a bug in your older build of VC?
Martin.
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
