mollaman
#1 Posted : Saturday, June 14, 2008 9:03:33 AM(UTC)
mollaman
Is there a way to import/export to Microstation .dgn files?
#2 Posted : Monday, June 16, 2008 12:17:17 PM(UTC)
Bad luck - I think nobody knows
Can MicroStation save out a dxf / dwg ?
I can imagine if you have an archive of drawings, this is a hassle
Sorry - best I can do
cadprog
#3 Posted : Tuesday, May 29, 2012 12:23:12 AM(UTC)
cadprog
If you have access to MicroStation you can export or import DXF and DWG files. The latest Version 7 can and V8 definitly. Look under the File pull down there should be a selection for import and/or export. Once the DXF?DWG is imported you can then save the file to a DGN format for Microstation.
posh.de
#4 Posted : Tuesday, April 21, 2015 8:32:32 AM(UTC)
posh.de
if you have no access to Microstation you might want use the free Teigha Viewer f. Win & OSX to convert DGNs from/to the standard for 2D data exchange = the DXF/DWG format.
hth
