Import/Export
DWG dimension text changes when saving (#3070)
                I opened a DWG file, made a change to a note, then saved it again.
                Originally Posted by: shawnb13
We could kidnap Tim, torture him a bit, then give the rest of the Punch team, a total frontal lobotomy. Oh you say they already have had lobotomies? ;)
This 25.4 bug has been mentioned several times. In fact I'm fed up with mentioning it. I'm so pleased I didn't upgrade to 7.
Btw, Rhino is looking good these days. Python integration via Mono, for Mac, has recently been announced, so a history tree is on it's way. 8)
sorry for the rant. My answer has no relation to your question, I'm just dissaponted with the progress of Shark. 25.4mm pops up a lot.
Usually the problem you are facing is mismatched fonts from one application to another. ACad is classic for this.
                Originally Posted by: shawnb13  I opened a DWG file, made a change to a note, then saved it again.
Hi Shawn
What version of ViaCAD are you using?  Can you do a quick example file and post the ViaCAD and dwg file?  I can use \P and export files out of ViaCAD and the return is ok in other programs.
(22kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Attached is the .vc3 files saved from ViaCAD 2D/3D v6.0.0
CONTROLHW1-RC.vc3
The dimensions appear correctly in when viewed in ViaCAD.
However, when I export this file to DWG and open with a viewer (Solidworks eDrawings), the dimensions include the \P instead of a carriage return.
Appears I cannot save the DWG file here to include in the post...???
Tried creating a sample drawing with stacked dimensions, but stack appears in ViaCAD and only one dimension appears in the viewer.
TEST1-VC.vc3
Still very new to ViaCAD and have not used it much...
 CONTROLHW1-R1C.vc3
(1,206kb) downloaded 5  time(s).  TEST1-VC.vc3
(8kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
                Hi Shawn
Originally Posted by: shawnb13  Attached is the .vc3 files saved from ViaCAD 2D/3D v6.0.0
Don't explode your dimensions. Open the dimension properties in Object info.  Select dimension hit ctrl I, in the text box delete the # sign to override the dimension type your own text in including using \P where needed.
You need to zip up files like dwg to be able to post.
Does not export dual dims yet.
No Problem, Post your questions and someone will help you...
 dimexamplewmultipline.vc3
(176kb) downloaded 5  time(s). jdi000 attached the following image(s):
(14kb) downloaded 5  time(s). You cannot  view/download attachments. Try to login or register.
Import/Export
cannot  reply to topics in this forum.
cannot  delete your posts in this forum.
cannot  edit your posts in this forum.
cannot  create polls in this forum.
cannot  vote in polls in this forum.
