Well after trying to find out what is happening, I have come to the conclusion that the 2 rail sweep can work, although it can be a case of having to attempt it a few times. :rolleyes:
An example of this is below.
01: 2 circles as rails with a rectangle as section to sweep
02: the result when the inside circle is picked first for the rails (incorrect)
03: After selecting the outside circle first for the rails, the correct result.
This does not always work, sometimes the rails need to be changed to other spline types, then a case of picking the correct rail first. So it is a little unpredictable, but can usually now get a result eventually.
A bit of an "Hit or miss" situation.
(123kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M ...........This does not always work, sometimes the rails need to be changed to other spline types, then a case of picking the correct rail first. So it is a little unpredictable, but can usually now get a result eventually. A bit of an "Hit or miss" situation.
There should be no order in which to pick curves to build a surface/solid...this "should" be a relatively simple fix for Tim/Ryan?
If like you say it takes multiple attempts to get a satisfactory result (if you havent given up by then) then to me the HELP is either useless or poorly documented OR you havent bloody read it !:D
Originally Posted by: unique If like you say it takes multiple attempts to get a satisfactory result (if you havent given up by then)
You should try it.
Originally Posted by: unique then to me the HELP is either useless or poorly documented OR you havent bloody read it !:D
The help file states nothing about pick order. nor the fact that rails need to be changed at times to other types for the rails to work. (Then again, there is nothing in the help file about pick order of sections for guide skin surfaces/solids.)
VC/Shark certainly does not appear to be a user friendly CAD, well certainly not on the PC.
- Steve
Example;-
http://rapidshare.com/files/245182773/2railsweep.avi
An example where 2 trimmed ellipse are used for the rails:-
http://rapidshare.com/files/245202272/2ellipserail.avi
Originally Posted by: Steve.M You should try it.
No thanks....I simply dont have the time or patience to muck about. Rhino produces this with just a few clicks and using nurbs curves, how many curves did you try :rolleyes::D:D
Originally Posted by: unique I simply dont have the time or patience to muck about.
My major problems with this come when I have 2 closed CP spline rails, as if/when the 2 rail sweep fails I need to convert, the problem then being, if I change the rails to Bezier, then the start point changes, if I change them to Int, then the start/end angles are lost. Not a major problem if the splines are planer, but a lot of the sweeps I make are in 3d space, so it is a nightmare.
Originally Posted by: unique Rhino produces this with just a few clicks and using nurbs curves,
I have gone back to Rhino for quite a number of models I have built, simply because I want what is expected to be produced on the first attempt, not to have to mess around changing selection/types :(
- Steve
Thanks: 115 times Was thanked: 117 time(s) in 78 post(s)
Is there a way to view these avi's without going thru rapidshare? If i can't directly click-n-run it or download for later review, i just close the page and think, "Next?"...
Same .. I'm with shorty !
Originally Posted by: jol Same .. I'm with shorty !
Click the links now for direct download.
ouch. That hurts :o :o :(
Originally Posted by: ZeroLengthCurve Is there a way to view these avi's without going thru rapidshare? If i can't directly click-n-run it or download for later review, i just close the page and think, "Next?"...
eh????? just hot run and direct thru media player or whatever player you have set as default. If you are a Mac user I have no sympathy....get a frickin PC:rolleyes::rolleyes:
Actually, I may be mistaken, but I think zerolengthcurve is a PC user! :p Works absolutely fine here! :D
Originally Posted by: Steve.M An example where 2 trimmed ellipse are used for the rails:-
Sorry, but can you tell me
exactly how you drew your rails. Whenever I try and reproduce your solid they come out as they are suposed to.
Originally Posted by: unique eh????? just hot run and direct thru media player or whatever player you have set as default. If you are a Mac user I have no sympathy....get a frickin PC:rolleyes::rolleyes:
Honestly, there are millions of places out there to have asinine arguments about PC/Mac
If You really feel the need to fight the oldest of all flame wars, I have no sympathy .... get a frickin‘ live.
Originally Posted by: billbedford Sorry, but can you tell me exactly how you drew your rails.
I created one Ellipse from origin (X0,Y0,Z0), then created a second offset along the X, I then created a trimming line on the X axis and trimmed the bottom half from both Ellipse. see pic.
Originally Posted by: billbedford Whenever I try and reproduce your solid they come out as they are suposed to.
I have tried this now in VC Pro 835 and Shark 835 (both PC versions) with same result.(and checked on a second PC with same result)
(56kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
I'd like to agree with Nabed .. there are lots of other places for that besides, we have our work cut out here
Originally Posted by: jol besides, we have our work cut out here
I agree.
Please, to all, I do not want this thread to go off topic. I believe these problems with the 2 rail sweeps need attention.
The only "Mac vs PC" I am interested in (in this thread), is if there is a difference in how the 2 rail sweeps are handled.
- Steve
