Solid Modeling
Guide skin solid (simple test) (#2394)
I have been looking at Shark and the Guide skin solid.
For a simple check I made 4 cross sections on an Ellipse
01: The cross sections and Ellipse for Guide.
02: The solid created
03: I trimmed off a section. Copied the edges for a check.
04: A view of the section edges.
Would this be deemed as correct :D
EDIT:
After changing the Ellipse to a Int-spline the result was better, however, the cross section had decreased in size on the width by over 10% on the section I made
(12kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
01: The cross sections and Ellipse for Guide. 02: The solid created 03: I trimmed off a section. Copied the edges for a check. 04: A view of the section edges. Hi Steve, I believe this is updated in 838 if you were to regen the part. (force regen in concept explorer via right click). Tim
Originally Posted by: Tim Olson I believe this is updated in 838 if you were to regen the part. (force regen in concept explorer via right click).
Hello Tim,
As I currently only use the demo of shark (for verification of any problems I find in pro) I will need to download the latest build to verify.
Will any changes be made to the
guide skin surfaces which currently give the same bad output as shown above? If yes, then will those optimizations be added to the pro version?
- Steve
EDIT
After a few checks I see very little improvement (and that is only on the guide skin solid, the guide skin surface as no improvement at all). Is it a case that Acis is not capable of this type of (which should be very simple) construction?
- Steve
Solid Modeling
