2D Drafting
Extend line to surface. (#2355)
Tim,
At one time (certainly in build 788, I have just re-checked) it was possible to extend a line to a surface boundary, attempting this now causes an error popup.
Note: It also (on pc build 835) after the error, causes the dynamic rotate (middle mouse button) to change to dynamic zoom.
Attached:
pic01 showing simple example (example file attached)
Pic02 show error, although the line is extended beyond the boundary.
- Steve
extend to surface.vcp
(10kb) downloaded 5 time(s). Steve.M attached the following image(s):
(59kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Tim, The trim to surface is also now giving errors, which does work in build 788. I hope this is just a bug and not a removed feature? - Steve
Steve, Repeated, found and fixed in 836. Thanks, Tim
I haven't tried the method you used. But, i get the dynamic zoom "bug" and i don't know why nor what triggers it. I usually dont' find out until 4 or 5 steps beyond, when i'm banging my head on the desk over non-response to dynamic (middle mouse button) panning. Hitting the back-tick key doesn't release the mode into select. So, i think i sometimes am not even getting selections, or if i do, i still don't fall into a mode permitting dynamic panning. I thought maybe VirtualBox had something to do with it, but in all respects i can recall, VBox has not caused my other apps to behave oddly or in quirky ways. I think VBox is not tripping VCAD up. I don't think my system resources are the problem. It's probably some code snag that's random, or based on some irreproducable (due to my memory span) chain of steps...
Originally Posted by: ZeroLengthCurve (due to my memory span)
I'm hearin' yer Bro! :D:D
Originally Posted by: ZeroLengthCurve But, i get the dynamic zoom "bug" and i don't know why nor what triggers it. I thought maybe VirtualBox had something to do with it,
No, it is the same on my setup. I did make note in my first post pointing out the problem.
- Steve
2D Drafting
