Snap to cone endpoint? (#2327)
Did not know which section to post this one. If there is a cone solid, or cone create via solid/surface revolve, or even a cone created using a chamfer, then the end point of the cone cannot be snapped to, it is not seen as an endpoint. Is this by design? - Steve
>>If there is a cone solid, or cone create via solid/surface revolve, or even a >>cone created using a chamfer, then the end point of the cone cannot be >>snapped to, it is not seen as an endpoint. >>Is this by design? I'm currently only grabbing snap points on geometry with length. Will need to investigate grabbing stand alone vertices. Tim
>>If there is a cone solid, or cone create via solid/surface revolve, or even a >>cone created using a chamfer, then the end point of the cone cannot be >>snapped to, it is not seen as an endpoint. >>Is this by design? I'm currently only grabbing snap points on geometry with length. Will need to investigate grabbing stand alone vertices as that is also a relative point to snap to. Tim
I nearly forgot to thank you for adding this snapping. Regards, - Steve
Tim, It appears that only the "Cone 2 points" can be snapped to at its endpoint. There is no endpoint snapping on the other cone types (or for created cones from chamfers etc). - Steve
Originally Posted by: Steve.M Tim, It appears that only the "Cone 2 points" can be snapped to at its endpoint. There is no endpoint snapping on the other cone types (or for created cones from chamfers etc). - Steve
Hi Steve,
In addition to curves, we also snap to points used by the designer to define the shape. So the Cone 3 Points is snapping to the second point used to define the cone.
