Well, I have seen some errors in VC, most of which are not understandable. I am really starting to think someone is taking the p&%^
(21kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Steve.M Well, I have seen some errors in VC, most of which are not understandable. I am really starting to think someone is taking the p&%^
Thats a new one.....pmsl :D:D
Steve, If you can send steps/file to repeat that would be great. Thanks Tim
Hi Tim, Sorry, I did not save the file, I got a little irritated with it and just closed VC pro. The error came up while attempting surface matching. As I am currently playing a lot with the surfaces I will see if I can reproduce and save the file. regards, - Steve
Hi Tim, I have been trying to recreate the problem. But this time i am getting VC pro crashing. (this is when attempting surface match) Faulting application Viacadpro 16.6.0.831 Faulting module admhusk.dll version 18.0.1.8008 fault address 0x0000d1e3 The PC I am currently using VC pro on is not networked, so it is a pain to copy over files etc. I will need to go out tomorrow and get a usb flash so I can make better reports. - Steve
