Steve.M
#1 Posted : Monday, May 4, 2009 10:24:31 PM(UTC)
Steve.M
Well, I have seen some errors in VC, most of which are not understandable. I am really starting to think someone is taking the p&%^
unique
#2 Posted : Tuesday, May 5, 2009 1:02:53 AM(UTC)
unique
Thats a new one.....pmsl :D:D
#3 Posted : Tuesday, May 5, 2009 8:44:47 AM(UTC)
Steve,
If you can send steps/file to repeat that would be great.
Steve.M
#4 Posted : Tuesday, May 5, 2009 6:14:03 PM(UTC)
Steve.M
Hi Tim,
Sorry, I did not save the file, I got a little irritated with it and just closed VC pro. The error came up while attempting surface matching. As I am currently playing a lot with the surfaces I will see if I can reproduce and save the file.
regards,
- Steve
Steve.M
#5 Posted : Tuesday, May 5, 2009 7:50:06 PM(UTC)
Steve.M
Hi Tim,
I have been trying to recreate the problem. But this time i am getting VC pro crashing. (this is when attempting surface match)
Faulting application Viacadpro 16.6.0.831
Faulting module admhusk.dll version 18.0.1.8008 fault address 0x0000d1e3
The PC I am currently using VC pro on is not networked, so it is a pain to copy over files etc. I will need to go out tomorrow and get a usb flash so I can make better reports.
- Steve
