Just playing again
No render, just a screen grab
(35kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Very good, Steve! You've done the most complex piece of the game... JL
Hey Steve, very nice! :cool:
Decided to make a render.
(85kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: jol You're the 'mane' man !
wa wa wa! lol!
No, I'm just horsing around.
bravo, trs bon et beau travail et trs propre. Antoine
beaucoup remercient monsieur - Steve
Originally Posted by: Tim Olson Very nice Steve!
Thanks Tim,
It certainly gave me new thoughts on how VC works with surfaces, even if some did make me lose a little more hair :D
- Steve
Steve What was your approach? Did you create surfaces from curves, then stitch and do feature operations? Tim
Hi Tim,
Originally Posted by: Tim Olson What was your approach? Did you create surfaces from curves, then stitch and do feature operations?
I made main surfaces then split and filled. The filled (feature) surfaces I made with the sweeps/net to see what results I could get. I did make some mistakes, so used the undo quite a few times.
- Steve
I thought I may as well carry on with this and finish the set.
Still the king and queen to do.
(100kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Tim, make sure that these go in the Punch gallery!! (with Steve's permission of course! :D )
I found bit more time for this.
Have made the board and the queen, just the king to do.
I have not decided on what material to use for the pieces yet, but have made a quick test render to show where I am.
- Steve
(397kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
A render of the finished set.
(191kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
