Tim,
Well, its all good for Shark getting new faceting, but what about the products you are selling/sold?
When I am building what should be a simple 30 minute model and getting problems with faceting that is then output to obj it makes VC pretty much useless for my projects.
I have attached pic01 from where I have simply added chamfers to some holes and the facets start to cover the holes up. I exported to a poly modeler to check if it was just a display problem but the output was the same with holes covered.pic02
I am really starting to get tired of the endless problems with VC. If this was V1 of the product line it would be classed as quite bad, but for V6 IMHO it is a complete embarrassment for the company.
- Steve
(7kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
stepping up or down the resolution usually fixes this you could also try restitching it .. just click it once with the stitch tool also verify object to see that acis hasn't got it's knickers around its neck agree it'd be better if it didn't happen - but it is quite rare now
Nothing is fixing this. There should be no need to have to mess aroung changing display etc just to get correct faceting.
The model is very simplistic, but did make a check to post you screen shot.
I did think that if I changed the object to surfaces then the model would be re-built to surfaces from the underlying geometry, however, when I did that, the surfaces appear to be built from the faceting info with the result shown in the second pic.
I am using what is described as a Pro version CAD system, when I stop laughing at that I may decide to attempt the model again in VC. (and note, this is also a problem in the latest build of 2d/3d)
- Steve
(26kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Do you want to post it Steve ? - maybe we can get Tim to look into it
Steve, If you send/post the VC file that would be very helpful. Tim
Tim, I over wrote the file. I am currently playing with the surfacing tools at the moment, but will go back and see if I can produce the problem again. - Steve
Tim,
I have come across another example.
The model was just a check on the behavior of the surfacing tools. The facets messed up pic01.
When loading the model it does take quite a time to load, it appears to get stuck on "Calculating facet display list", but it does eventually load.
- Steve
mesh problems2.vcp
(273kb) downloaded 5 time(s). Steve.M attached the following image(s):
(72kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
>>The model was just a check on the behavior of the surfacing tools. The >>facets messed up pic01. Steve This repeats for me as well. Bringing the file into our app based on ACIS R20 appears to fix the issue. Tim
Originally Posted by: Tim Olson Bringing the file into our app based on ACIS R20 appears to fix the issue.
This is a problem with ACIS then?
App based on R20? What's that? :D
>>This is a problem with ACIS then? It appears to be. >>App based on R20? What's that? Current ViaCAD and Shark products are based on the ACIS R18 modeling kernel from Spatial. We're working on the next major release which is using ACIS R20. Tim
hello,
Quote: This repeats for me as well. Bringing the file into our app based on ACIS R20 appears to fix the issue.
Dassault/Catia make aircraft designs ... flying ....
with an kernel ... with bug?
olala
It makes you think doesn't it? :eek: :D:D Poor old Tim. Actually, from what I read on Solidworks-based forums is that SW's users are having buggy problems too (sorry can't be over specific here- have a look for yourselves!). So perhaps we can blame that naughty buggy ACIS kernel after all? Hey Tim, fancy switching to Parasolid? :cool:
Now I always wondered .. Since Dessault owns ACIS and SolidWords - but not ParaSolids .. aren't they tempted to use their own Kernel to drive SW ? Ultimately, it seems silly to pay for someone else's when you have your own Maybe this is why ACIS has got so much better in the last few years ?
Originally Posted by: jol Now I always wondered .. Since Dessault owns ACIS and SolidWords - but not ParaSolids .. aren't they tempted to use their own Kernel to drive SW ? Ultimately, it seems silly to pay for someone else's when you have your own Maybe this is why ACIS has got so much better in the last few years ?
I ask the guys at Spatial that frequently. Spatial would certainly like to see that happen but SolidWorks pretty much marches to it's own tune as part of the Dassault family. FYI, SolidWorks does have a few ACIS dlls included (SAT read/write and deformable modeling).
I think it's challenging to switch when you have a large installed user base of data files. Partially because designers are rightly demanding in preserving 100% of their data file integrity. A history based model must regen the part consistently. Converting between ACIS and Parasolids is very good, but there are enough differences where I don't think you can always guarantee 100% conversion. (This is a contrary opinion to some cad bloggers out there, a kernel is much more than a collection of NURB surfaces...)
Some years back at Lockheed we were switching from CADAM to CATIA. Our CATIA rep was IBM. They assured us that 98 percent of our files would come over from CADAM to CATIA perfectly. And this was 2 1/2D! We had thousands of master drawing files of the F-16 and F-16 derivatives in CADAM. Since we did not know what 2 percent would fail on our $20M airplane, we kept the master database in CADAM.
SolidWorks is also in an intense dogfight with Inventor for top dog in the 5K MCAD market. I'm not sure they can afford any slips right now. I remember when SolidEdge switched from ACIS to ParaSolids. I think the year it took them to switch the kernel gave SolidWorks a significant competitive edge as SolidWorks aggressively added new functionality. At that time and even today, I thought SolidEdge was a superior product, especially with drafting and sheet metal.
