Hello, I have just got around to installing the 2d/3d build 787 (win XP) I find I cannot enable the "Show Curvature" for checking curves from the drop down menu. I set up a shortcut key but that only works if I have the mouse over the actual curve before I press the shortcut (even though the curve is already selected). Regards, - Steve
>>I find I cannot enable the "Show Curvature" >>for checking curves from the drop down menu. Is it possible that you are not in the arrow tool? Tim
I was in the selection(arrow) tool to first select the curve for analysis. The drop down menu(verify) "show curvature" is not working on this setup with this build,
I cannot get show curvature to work unless I add a curvature circle and select both items. Then the curvature works. Shortcut key works if the cursor is on top of the curve Jason Viacad v6 787 Vista
Hi Jason, Yes, that works on mine too lol Have you tried a shortcut key as I mentioned in my first post?
It seems to be ok on the Mac. Does Ryan need to get that ?
This is still not working in build 788.
Steve.M wrote: This is still not working in build 788.
Steve,
I believe I finally fixed it in 789. It was related to a variable not getting defined which is why it worked on some machines and not others.
Hi Tim, Confirmed as fixed in 790. Thanks, - Steve
