Steve.M
#1 Posted : Tuesday, July 15, 2008 4:25:50 AM(UTC)
Steve.M
Hello,
2d/3d V6 (build)787 (PC)
When using control point splines, I can use "Modify slope"~ "Reference" for a slope which then usually goes the wrong way, but when using control point splines the "Reverse" will not reverse the curve direction made by the Reference.
- Steve
Steve.M
#2 Posted : Tuesday, July 15, 2008 5:14:44 AM(UTC)
Steve.M
I thought changing the "object type" of spline may help, but instead the program simply crashed.
#3 Posted : Tuesday, July 15, 2008 6:11:37 AM(UTC)
I really don't know how many times through the years I've stated that 'reference' slopes go the wrong way by default
Thanks for bringing up again
Perhaps if other people can verify this issue - we can finally get this changed !!
#4 Posted : Tuesday, July 15, 2008 10:43:50 AM(UTC)
Steve,
Any more info on how to repeat? Do you still have the file? If so email and I will see if its fixable for tonights upload.
Steve.M
#5 Posted : Tuesday, July 15, 2008 10:56:48 AM(UTC)
Steve.M
Hi Tim,
I was not expecting(or looking for) a crash, so did not keep notes of steps etc as I was just drawing many different types of spline to check the "Modify slope" tool.
I cannot repeat the crash at this time, but will keep better track in case it happens again.
- Steve
#6 Posted : Tuesday, July 15, 2008 12:59:36 PM(UTC)
Steve.M wrote:
Hello,
...using control point splines the "Reverse" will not reverse the curve direction made by the Reference.
- Steve
Steve
Fixed in 788.
Steve.M
#7 Posted : Tuesday, July 15, 2008 2:07:40 PM(UTC)
Steve.M
Hi Tim,
Tim Olson wrote:
Steve
Fixed in 788.
Thank you,
By the way, the problem appears in shark FX(pc) demo
Regards,
_ steve
#8 Posted : Tuesday, July 15, 2008 2:10:45 PM(UTC)
so will 'reference' ing a spline into a surface or solid now no longer require reversing every time ?
#9 Posted : Tuesday, July 15, 2008 3:33:39 PM(UTC)
Not yet, this just adds the ability to reverse the start/end slope of a control point spline. The extra flipping is based on which side of the surface you reference which I have not addressed yet.
Steve.M
#10 Posted : Thursday, July 17, 2008 3:47:21 AM(UTC)
Steve.M
Hi Tim,
Tim Olson wrote:
Steve
Fixed in 788.
This is still not working on the control point splines (788).
- Steve
#11 Posted : Thursday, July 17, 2008 9:40:47 AM(UTC)
Steve.M wrote:
Hi Tim,
- Steve
Steve
Can you send me an example?
Steve.M
#12 Posted : Thursday, July 17, 2008 12:51:17 PM(UTC)
Steve.M
Tim Olson wrote:
Steve
Hi Tim,
e-mail sent with simple example.
- Steve
Steve.M
#13 Posted : Friday, July 18, 2008 9:13:49 AM(UTC)
Steve.M
Hello,
I did find that is was own fault on this one.
I was expecting to select the control point spline near the end to change its direction, when in fact I need to select the actual control point.
I e-mailed Tim with the explanation of my error.
- Steve
