Steve.M
#1 Posted : Sunday, July 13, 2008 8:22:30 AM(UTC)
Steve.M
Hello,
Due to the problems with the surface G1/G2 (reported here http://forum.punchcad.com/showthread.php?t=1263) I have been building from curves. I have been finding some problems, so have again gone back to basics.
On the xy plane I drew 2 splines at tangent leaving a gap so the "join" would then, as the user guide states
Quote:
Join Curve:
The join Curve tool is used to smoothly join 2 curves. Joining of the curves will create a single curvature continuous curve from the original curves
The results do not show that.
As the example:-
Pic 1: 2 spline tangent curves
Pic 2: The join made
Pic 3/4: Curvature check showing bad curvature
Pic 5: Curve Blend/join made and checked in Rhino
Regards,
- Steve
unique
#2 Posted : Monday, July 14, 2008 1:13:53 AM(UTC)
unique
Hi Steve,
Hmmm Yeah that is strange....I hadn't come across that yet because I have been sketching degree 1 curves thus far and that combination provides G0 results. However, something is wrong with this command - Tim ??
A more appropriate cmd might be 'smooth fill curve' otherwise known as a blend curve...this can found in the fillet/chamfer palette.
Steve.M
#3 Posted : Monday, July 14, 2008 3:59:59 AM(UTC)
Steve.M
Hi Paul,
In 2d space the "smooth fill curve" does appear to be better than the join, but go into 3d space and the "smooth fill curve" gives some very strange results, I was leaving those examples/questions until some feedback from the developers on the already opened questions I have.
unique
#4 Posted : Monday, July 14, 2008 5:17:52 AM(UTC)
unique
:D ohhhh dear I see what you mean.
The smooth blend in the file attached is how it should look ?
3d Blends.zip (2kb) downloaded 6 time(s).
Steve.M
#5 Posted : Monday, July 14, 2008 5:46:16 AM(UTC)
Steve.M
Hi Paul,
Which attached file? (edit: you added the file as I was posting: I will look later)
Those I attached to the first post are showing the "Join" which should be giving correct curvature.
The "Smooth fill curve",.. I am not yet completely sure what it is doing,.. it looks like some extension to the original lines to an interception point, then a blend is made from the new end points,.. which is not what is expected/wanted.
I have attached 2 pics showing 2 curves (both on different planes,.. but the planes are at 90)
Pic "Rhino" shows a blend in Rhino, which then does give me a number of options (G1/G2 etc) and results expected
Pic "Shark" is the result of a "Smooth fill curve" with no additional option given, and not expected/wanted
I did attempt a "Join" between the curves in Shark,, but there was no good curvature.
