Reuben5150
#1 Posted : Tuesday, June 26, 2007 5:22:45 AM(UTC)
Reuben5150
Is there no way to translate objects when all snapping is turned off ?
I know you can use the translate, rotate and scale tools but thats not what i mean, with snapping turned on you can simply grab an object and move it, should it not still work this way with the snaps off ?
Reuben
Todd Quinlan
#2 Posted : Tuesday, June 26, 2007 7:23:10 AM(UTC)
Todd Quinlan
Yes, you can use all the transform tools with snaps off. The will obviously not be as precise as if you were actually snapping to a specific point, but they will act the same whether the snaps are on or off.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
Reuben5150
#3 Posted : Tuesday, June 26, 2007 4:22:14 PM(UTC)
Reuben5150
Sure, but i meant when using the selection tool, usually you can select and drag the desired object, but with snapping turned off you cannot ?
thanks
Reuben
dexter
#4 Posted : Tuesday, June 26, 2007 6:44:34 PM(UTC)
dexter
I'd like to second Reuben's comment - it's as though you can't drag something when all snaps are off.
joev
#5 Posted : Tuesday, June 26, 2007 8:25:20 PM(UTC)
joev
Same with me. Snaps off - not able to select an element.
dexter
#6 Posted : Monday, July 16, 2007 10:11:58 AM(UTC)
dexter
Any more thoughts into this?
#7 Posted : Monday, July 16, 2007 2:58:30 PM(UTC)
Confirmed bug we need to fix.
joev
#8 Posted : Tuesday, July 17, 2007 9:40:09 AM(UTC)
joev
It's a problem with Concepts 3D (Mac) as well, not just ViaCAD.
#9 Posted : Sunday, July 22, 2007 10:03:58 AM(UTC)
This is now fixed for the next service pack.
Thanks all!
Reuben5150
#10 Posted : Sunday, July 29, 2007 6:29:03 AM(UTC)
Reuben5150
Great news, thanks !
Reuben
