rojharris
#1 Posted : Monday, June 4, 2007 12:56:17 PM(UTC)
rojharris
I am wondering if there's a way to show background layers (i.e. the ones I'm not wirking in) in a ghosted or wireframe manner so I can use them as reference for the current layer without them getting in the way and hiding my geometry?
regards
Roger
joev
#2 Posted : Monday, June 4, 2007 8:21:18 PM(UTC)
joev
Import your bmp file into the planar view of choice.
Select the image and Under Object Info, click the transparency box. Hit the Apply button. Click in the window area and your image will be ghosted.
You should put your images on their own layer and lock the layer.
rojharris
#3 Posted : Tuesday, June 5, 2007 2:14:59 AM(UTC)
rojharris
Hi Joev,
Thanks, but I don't mean background images, I mean background layers, with geometry in them. So for example you could make one part in one layer, then start a new layer and model the next part relative to the first, still visible, but in a different display style, like wireframe for example.
All other 3d packages I've used can do this in one way or another and I was wondering if viaCAD has a way to do it too.
I don't want to be able to hide layers or even keep them visible and fully shaded. I want them to be locked in the background, still visible and snappable (optional) but somehow ghosted/wireframed etc.
roger
joev
#4 Posted : Tuesday, June 5, 2007 8:09:58 AM(UTC)
joev
OK, I know you can lock and make objects transparent, but I don't see a way to have only certain objects wireframe.
rojharris
#5 Posted : Tuesday, June 5, 2007 9:37:46 AM(UTC)
rojharris
OH...Making the objects transparent (but visible) would work perectly. How do I do that? I can't seem to find it.
cheers
Roger
NickB
#6 Posted : Tuesday, June 5, 2007 11:41:23 AM(UTC)
NickB
You are right, you can't set view properties on a per layer basis. There is no work around other than what you are doing: turning layers on and off, hiding and showing, transparency on a per object basis, and constantly flipping from shaded to wireframe.
Some things you could do, are use the the selection mask - in the windows menu to limit your selection to a certain layer, then select all and turn transparency on in the edit object dialog.
If you find yourself constantly flipping from wire to shaded modes you might want to set up a keyboard shortcut to speed this up a bit.
Shark FX 9 build 1143
OS X 9.5
matter.cc
rojharris
#7 Posted : Tuesday, June 5, 2007 12:19:59 PM(UTC)
rojharris
Thanks Nick. I'll have a go at that
#8 Posted : Tuesday, June 5, 2007 2:36:52 PM(UTC)
A ghost icon was created for the layer manager - and a fine little ghost he was too
I thought that the lock check box could perhaps cycle through a ghost option
Ghost being, as you suggest .. faint reference material that can be optionally snapped to
It certainly wasn't a priority back then .. perhaps the guys have time to take another look this time round ?
I also did a tape measure icon hoping that might come up soon too .. neither of these were requested
#9 Posted : Wednesday, June 6, 2007 7:25:41 AM(UTC)
>>I am wondering if there's a way to show background layers (i.e. the ones >>I'm not wirking in) in a ghosted or wireframe manner so I can use them as >>reference for the current layer without them getting in the way and hiding >>my geometry?
You might be able to use the layer manager to lock these layers and then use a layer color override to set to a light white color.
