2D Drafting
Problem Dimensioning Fillets in Model-to-Sheet Views (#3674)
Hello everyone. I've recently purchased ViaCad Pro 6. I have a part that I've modeled in 3D that has filleted features. When I turn the 3D model into 2D views using "model-to-sheet" I am unable to dimension the diameters with fillets applied in the appropriate 2D view using any of the radial-out or smart-dimension tools. When I remove the fillet in the visible view, then I'm able to dimension the diameter. If I set the fillet in a hidden area, the radial dimension tool works fine in the visible portion. Please help. I am using ViaCad Pro 6 (build 853) on a Quad Core Mac running OS 10.6.6.
Please see attached screen recording.
mod_2_sheet_dim_prob.mov.zip
(1,640kb) downloaded 7 time(s). mod_2_sheet_dim_prob.vcp
(81kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Hi Rick Can you try reloading movie or some screenshots. Regards Jason
Hi Jason, I've re-uploaded a zipped quicktime movie file. Hope this helps. Thanx, Rick
Hi Rick I see you movie, can you post the sample file you made the movie with? Thanks Jason
Originally Posted by: jdi000 Hi Rick I see you movie, can you post the sample file you made the movie with? Thanks Jason
Here ya go Jason. All I can think of is that it is a bug in this build.
Thanks for your help.
Rick
2D Drafting
