RichjBrown
#1 Posted : Monday, January 16, 2012 11:20:23 AM(UTC)
RichjBrown
I have only just downloaded the viacad software. At first on my iMac, then on my MacBook.
On the iMac, every time i try and insert a door or window into a wall, i get the error message "not enough room for wall feature"
On my MacBook it seems to be working OK though....
Any suggestions?
#2 Posted : Monday, January 16, 2012 2:33:19 PM(UTC)
Hi Rich
That usually means you are placing the door/window too close to a corner or that the door/window width is longer then the wall width.
RichjBrown
#3 Posted : Monday, January 16, 2012 4:00:30 PM(UTC)
RichjBrown
Hi Tim
Im now experiencing the same problems on my MacBook
I jut draw a 13' wall and tried to put a 2'6 door in the middle and the same error code comes up. it also won't let me put doors in the drawing i managed to draw them into earlier.... very annoying.
i don't know if its an 'angle' problem. the angle is saying 3937.008?? I've tried changing this but still no luck
richard
#4 Posted : Monday, January 16, 2012 5:11:12 PM(UTC)
Hi Richard
Can you upload your viacad file to the forum?
I'll make a quick .mov demo showing how to add door/window to your layout.
Art
#5 Posted : Thursday, February 14, 2013 9:37:55 AM(UTC)
Art
I am having the exact same door and window problem. "Too close" error as well as many crashes. Not too useful.
Does anybody use the architectural features?
I also notice that the walls do not automatically connect like they should.
A minor point is that I also miss the "option" command for flipping the side the wall is generated on. I asked Todd and he did not know when that feature was deleted.
Art Shark FX 8.0.3 1014
Mac 10.6.8
posh.de
#6 Posted : Friday, February 15, 2013 9:32:37 AM(UTC)
posh.de
an old bug, if I remind correct this happens if the unit prefs differs from inches or millimeters, i.e. problem happens if using feets or meters etc.
Norbert
Art
#7 Posted : Friday, February 15, 2013 12:32:22 PM(UTC)
Art
Thanks for the note.
I will play with it to see if there is a pattern. I sure miss the "flipping" walls!
I also notice that walls do not "self heal" . Placing another intersecting wall heals, but still not very clean.
Art
Shark FX Mac
