VC Pro 7 why no viewball ? (#3795)
Hello, I've just upgraded from concepts 3d to viacad pro, i cannot find the viewball anywhere, if its been taken out then why ? Thanks
I think I'm right is saying that Concepts upgraded to Shark ViaCAD was a new range and has a different toolset There are quite a few tools available in Shark that are not in ViaCAD
is there an upgrade path from vc to shark ? thanks
I don't know but you could call them - they used to do a really fair upgrade / cross-grade. They're usually pleased to help with these things. Where are you ? Perhaps someone else here knows ?
Viewball is still there, it's just been renamed to Navigator under Window in the Short Cuts section. Martin.
really - I can't find it in ViaCAD - can you post a screenie ?
Originally Posted by: jol really - I can't find it in ViaCAD - can you post a screenie ?
Here you go.
Martin.
(129kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Brilliant find - I'm not sure Tim meant that to be there still - so we better keep quiet : )
Originally Posted by: blowlamp Viewball is still there, it's just been renamed to Navigator under Window in the Short Cuts section. Martin.
Great thanks.
Originally Posted by: jol I think I'm right is saying that Concepts upgraded to Shark ViaCAD was a new range and has a different toolset There are quite a few tools available in Shark that are not in ViaCAD
If this is true the i feel like i've drawn a short straw here, as far as i know concepts 3d became viacad pro they seem to have the same toolset, i remember checking this, i only ever remember being offered upgrades to either viacad or shark FX which is probably overkill for what i need.
Last time i looked Shark LT sits at the same price point as Concepts 3d did, i was never offerd an upgrade to LT, so my 499usd investment has become a 250 one, there needs to be some clarity here.
Reuben
Six different products does seem a tad overkill
Thanks: 115 times Was thanked: 117 time(s) in 78 post(s)
ViewBall/Navigator used to be much easier to find and activate. It seems my shortcut stopped working and I stopped caring because it was something i jsut had had to bury in the deep recessess of my forgetfullness.
Yes, I suspect it's not supposed to be there at all in ViaCAD ! Tim - can you put it in properly .. or take it out properly !
Not sure why, but my Viewball/Navigator is working fine, hehehehe... And, I assigned it Shift+O to toggle it on and off. Maybe it IS supposed to be there, but it is just not being rivetingly spot-lit like the Gripper?
