Reuben.F
#1 Posted : Saturday, June 11, 2011 10:56:35 AM(UTC)
Reuben.F
Hello,
I've just upgraded from concepts 3d to viacad pro, i cannot find the viewball anywhere, if its been taken out then why ?
#2 Posted : Saturday, June 11, 2011 11:09:07 AM(UTC)
I think I'm right is saying that Concepts upgraded to Shark
ViaCAD was a new range and has a different toolset
There are quite a few tools available in Shark that are not in ViaCAD
Reuben.F
#3 Posted : Saturday, June 11, 2011 11:50:49 AM(UTC)
Reuben.F
is there an upgrade path from vc to shark ?
thanks
#4 Posted : Saturday, June 11, 2011 1:04:27 PM(UTC)
I don't know but you could call them - they used to do a really fair upgrade / cross-grade. They're usually pleased to help with these things. Where are you ?
Perhaps someone else here knows ?
blowlamp
#5 Posted : Saturday, June 11, 2011 6:21:30 PM(UTC)
blowlamp
Viewball is still there, it's just been renamed to Navigator under Window in the Short Cuts section.
Martin.
#6 Posted : Sunday, June 12, 2011 1:58:40 AM(UTC)
really - I can't find it in ViaCAD - can you post a screenie ?
blowlamp
#7 Posted : Sunday, June 12, 2011 3:14:09 AM(UTC)
blowlamp
Here you go.
Martin.
#8 Posted : Sunday, June 12, 2011 4:48:23 AM(UTC)
Brilliant find - I'm not sure Tim meant that to be there still - so we better keep quiet : )
Reuben.F
#9 Posted : Sunday, June 12, 2011 9:26:00 AM(UTC)
Reuben.F
Martin.
Great thanks.
Reuben.F
#10 Posted : Sunday, June 12, 2011 9:35:05 AM(UTC)
Reuben.F
If this is true the i feel like i've drawn a short straw here, as far as i know concepts 3d became viacad pro they seem to have the same toolset, i remember checking this, i only ever remember being offered upgrades to either viacad or shark FX which is probably overkill for what i need.
Last time i looked Shark LT sits at the same price point as Concepts 3d did, i was never offerd an upgrade to LT, so my 499usd investment has become a 250 one, there needs to be some clarity here.
Reuben
#11 Posted : Sunday, June 12, 2011 4:01:41 PM(UTC)
Six different products does seem a tad overkill
#12 Posted : Tuesday, July 5, 2011 12:33:54 PM(UTC)
ViewBall/Navigator used to be much easier to find and activate. It seems my shortcut stopped working and I stopped caring because it was something i jsut had had to bury in the deep recessess of my forgetfullness.
#13 Posted : Tuesday, July 5, 2011 12:58:49 PM(UTC)
Yes, I suspect it's not supposed to be there at all in ViaCAD !
Tim - can you put it in properly .. or take it out properly !
#14 Posted : Tuesday, July 5, 2011 3:10:24 PM(UTC)
Not sure why, but my Viewball/Navigator is working fine, hehehehe...
And, I assigned it Shift+O to toggle it on and off. Maybe it IS supposed to be there, but it is just not being rivetingly spot-lit like the Gripper?
