Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Is there anyway to wrap an image round a sphere?
Yes. Make it a Decal. Making Decals is an involved process that requires a positive and negative mask, and for even decent results you need a high resolution image. I usually go for 300dpi. You can see an example decal (on a flat surface) [URL="http://forum.punchcad.com/showthread.php?t=1417"]here[/URL]. All of the graphics is a single decal. The bitmaped artwork was around 10mb.
Shark FX 9 build 1143
OS X 9.5
matter.cc
Thanks Nick, but this will not work for what I had in mind as the decal only shows on rendering. I wanted to use an image in the same way Nick in the UK used the mountain bike picture in his tutorial. I was thinking about creating a sphere, wrapping an image of earth to it and then trace the outlines of the continents using the spline on a surface function.
Craig Ryan is adding a button in the next ViaCAD 2D/3D v7 beta to add a custom texture to an object. Tim
Originally Posted by: admin Craig Ryan is adding a button in the next ViaCAD 2D/3D v7 beta to add a custom texture to an object. Tim
Tim,
I am running Shark FX, will this function be added to FX?
Craig
>>will this function be added to FX? Ryan is looking into adding this for lightworks photorendering for an upcoming FX beta. Currently it just works for opengl rendering. Tim
