Suggestions
error visualization.... (#4327)
Thanks: 6 times Was thanked: 29 time(s) in 16 post(s)
When checking solids with the check object feature. I get cryptic errors and as long as repair does what it should, all is ok. But sometimes it does repair the object to ok-status but some surfaces are scrambled after that. In many cases it was better to see the problem highlighted in 3D view and repair the surfaces, open edges etc. by myself.... Is that a possibility? I remember some years in the past the stitch into solid function did that with open edges... I have a view cores left on idle when using Shark. Wasnt it possible to have a "check object" task running on other cores in the background, checking all the geometry when altered and showing appearing errors as it discovers them?
Suggestions
