daleroe
#1 Posted : Wednesday, February 9, 2011 4:11:15 PM(UTC)
daleroe
I'm a longtime cobalt user new to shark. I'm having issues with the microscribe which is also new to me. The microscribe is used and I think there may a problem with it. Here is what happens:
I initialize the mscribe origin, x, y and for the extents I'm using the far x and y. Is this correct?
I select the Digitize curves icon, points, .010, .001
I touch the mscribe point to the part, step and hold the pedal while tracing the part. I can see all the points on the screen, however when I let up on the pedal most of the points disappear. The points that are left are not .010 apart. I've tried this with a nearly straight line at 1.0 intervals and get different distances also. The first one was around .750 and the second .860 etc.
If I try the same with a spline the spline looks just like the part until I let up on the pedal.
--dale
HP Z800 Dual Xeon 5690 3.46Ghz 64GB
nVidia Quadro 6000 6GB
Win pro 7-64
SharkCAD Pro v10.0.0 B1354
Shark FX v9.0.4 B1162
#2 Posted : Friday, February 11, 2011 3:20:12 PM(UTC)
Hi Dale
I know there are issues with Windows 7. Revware is working on a driver update. Are you on Win 7 by chance?
daleroe
#3 Posted : Monday, February 14, 2011 11:33:27 AM(UTC)
daleroe
Tim,
I'm on winXP. Could you please clarify the initialization proceedure. After I pick the origin, a point on x and a point on y what do I choose for the extents? Do I pick the far points in the xz and yz planes?
I've played with this thing some more and here is what I'm finding:
Working in the xy plane, using a graduated steel angle with the corner as origin I am tracing from x2 to x12 for a total of 10 inches measured.
- If I use the point tool from the normal tool palette and visually click at 1 inch increments for a total of 11 points I get between .098 to 1.01 with a total distance of 9.99.
- If I use the digitize curves in the microscribe palette, set to 1 inch points, step on the pedal and slowly follow the straight edge, letting up on the pedal at the end. I get 15 points ranging from .021 to .850 with the total distance at 9.89.
Win pro 7-64
#4 Posted : Monday, February 14, 2011 11:49:27 AM(UTC)
Send me your email address to tim.olson@evo-soft.net.
I've got a getting started guide for a private label we do for Revware & the MicroScribe that may help make sure the device is initialized correctly.
daleroe
#5 Posted : Tuesday, February 15, 2011 11:17:40 AM(UTC)
daleroe
Tim,
Thank you for the information. Neat application for concepts and the scribe. I've read all through it and still have some questions. I believe the extents for initialization are the far points in the zx plane and the zy plane, is that correct?
What I'm trying to create is a digital shore line from a navigational chart. The customer only wants a representational shape, however even with my points set at .010 and the deviation at .001, I'm not even close. If I watch points created on the screen it looks fine, however when I let off of the pedal to create the spline I get something vastly different that doesn't even resemble the shore line. I think Shark is tracking the movement of the scribe however the data points aren't representative of the small scale.
Perhaps the problem lies with me. I'm not sure I understand the data I should be getting, please correct me if I'm wrong.
1)If I select the points tool from the scribe menu I should get points the set distance along the path that I travel. The points may not measure the set distance depending on direction of travel, however if traveling in a straight line they will be at set intervals.
2)With Poly lines the length of the line will be the longest length possible and still fit the point data as described in #1.
3)The same conditions apply to splines, however the spline will pass through the points within the deviation setting.
The best data I can get is with the standard point spline tool and clicking allot of points. The trace spline tool acts like the data that I'm getting with the scribe tools.
--dale
Win pro 7-64
daleroe
#6 Posted : Friday, February 25, 2011 6:58:47 PM(UTC)
daleroe
Tim,
I really appreciated your quick responses in the begining. What happened? Everyday I check my email and this post waiting to hear back from you. I see that your logging in to the forum and posting regularly. I've sent you an email and a private message. Nothing... my questions have gone unanswered. Did I do or say something to offend you? Are you researching the answers?
Either I don't understand how the microscribe works, the software isn't working correctly or the hardware isn't working correctly. I don't have enough information to sort out the answer. I'm frustrated, I'm not getting answers here or from revware.
-dale
Win pro 7-64
L. Banasky
#7 Posted : Sunday, February 27, 2011 5:04:31 AM(UTC)
L. Banasky
Hi Dale,
I don't know much about Microscribe, but I did a search in
http://www.eng-tips.com/
and it looks like it is similar to the Faro arm, and information may be available from the users at eng-tips.
daleroe
#8 Posted : Tuesday, March 1, 2011 11:34:24 AM(UTC)
daleroe
Larry, Tim:
Thank you for the link. I read alot of digitizer arm related accuracy at the eng-tips forum although none of them addressed my questions of how shark fx handles the data. Tim is obviously the one who can answer the questions of how to initialize the microscibe within shark fx. He is also the one who can answer how the data from the microscribe is handled within shark fx. The tools are not working how I expect it to. I'm simply asking Tim to tell me what to expect so I can evaluate if and where my problem resides. I have ran the calibration tests for the microscribe and found everything within spec. More rigorus testing may be needed however, I really don't want to incure that expense if it's not actually needed. I'd really like to hear from you on this Tim. Any help would be greatly appreciated. Are others having similar issues or am I the only one using a microscribe within shark fx?
--dale
Win pro 7-64
