API
#1 Posted : Monday, July 28, 2008 8:24:30 AM(UTC)
API
I used to export a DXF with an imbedded SAT file to GibbsCAM. In Ver 5.5 it crashes Gibbs. I can however import a DXF with just geometry and I can import a SAT file. Something happened to the combination export. I'm exporting V13.
Patrick
damiane
#2 Posted : Wednesday, July 30, 2008 9:15:39 AM(UTC)
damiane
When did Shark 5.5 come out. I've got 5.0.0 which is release 737. Am I missing out here?
#3 Posted : Wednesday, July 30, 2008 9:16:53 AM(UTC)
It just did Damiane .. but it's a beta so tread carefully
#4 Posted : Wednesday, July 30, 2008 12:54:43 PM(UTC)
Patrick
Hi Patrick
I made a block with fillet blends and saved as a R13 DXF file. Then imported aok (SAT data preserved) to Inventor LT and DWG TrueView.
Can you check that you have a DXF folder inside your Shark FX 5.5 folder? Do you have read/write access to the DXF folder?
