API
#1 Posted : Tuesday, February 19, 2008 8:55:47 PM(UTC)
API
i think this has been around for a while. There are times when viewing in wireframe mode I can't select solids. I could be the entire solid or just a face during a move face command for example. Sometimes when I click near the edges, the solid will select. The only thing that consistently works is to go to shaded mode and then back to wireframe mode. The other two seats we own are having the same issue. Are we the only ones?
Patrick
Dual G5, Quad Intel, MacBook Pro
Nick R
#2 Posted : Wednesday, February 20, 2008 2:10:32 AM(UTC)
Nick R
I see this selection problem in wireframe quite often. Switching to shaded view seems to allow selection.
Nick Robinson
Nicholas Robinson Design
ALBANO
#3 Posted : Wednesday, February 20, 2008 5:23:53 AM(UTC)
ALBANO
Was thanked: 28 time(s) in 15 post(s)
have the same problem.
ALBANO
Art
#4 Posted : Saturday, February 23, 2008 8:40:37 PM(UTC)
Art
I did not have this problems in CU. I just upgraded to Shark and this is a pain.
Surely this is easy to fix?
Art
MacIntel
Shark 5-738 (according to the splash)
#5 Posted : Sunday, February 24, 2008 11:21:23 AM(UTC)
>>i think this has been around for a while. There are times when viewing in >>wireframe mode I can't select solids. I could be the entire solid or just a >>face during a move face command for example. Sometimes when I click >>near the edges, the solid will select. The only thing that consistently >>works is to go to shaded mode and then back to wireframe mode. The >>other two seats we own are having the same issue. Are we the only ones?
In wireframe mode, we don't regenerate the facets to improve performance in wireframe mode. But... if the facets are not there, it's supposed to pick the NURB/analytic faces.
I'll check it out why its not picking the nurbs stuff if the facets are not present. I've repeated here as well.
#6 Posted : Sunday, February 24, 2008 11:22:18 AM(UTC)
In wireframe mode, we don't regenerate the facets to improve performance in wireframe mode. Normally selections are based on facets. But... if the facets are not there, it's supposed to pick the NURB/analytic faces.
I'll check out why its not picking the nurbs stuff if the facets are not present. I've repeated here as well.
Art
#7 Posted : Sunday, February 24, 2008 12:14:56 PM(UTC)
Art
Tim,
Thanks.
I assume you know it happens to surfaces as well.
Art
MacIntel Shark FX
#8 Posted : Sunday, February 24, 2008 12:56:18 PM(UTC)
Art wrote:
Tim,
Thanks.
Art
MacIntel Shark FX
Yup! Just fixed for surfaces and solids. Correction is in next service pack.
David Gross
#9 Posted : Monday, February 25, 2008 11:47:44 AM(UTC)
David Gross
Tim how long before we can see this update because this bug is vary costly to me and can we fix the the model to sheet line scales, the plan views scale are 1 and the sections are 0 when exported to Autocad v13. These bugs are unacceptable.
David Gross
Dmg Design
Colgate, Wi.
