Import/Export
Shark Import of DXF 2000 (#1187)
I imported an AutoCAD 2000 file into Shark 747 and the result was poor, items mis-aligned, no dimensions etc. I imported the same file into CU V2 build 581 and the file is fine. That doesn't seem right. Do you want screen shots? Patrick
API wrote: I imported an AutoCAD 2000 file into Shark 747 and the result was poor, items mis-aligned, no dimensions etc. I imported the same file into CU V2 build 581 and the file is fine. That doesn't seem right. Do you want screen shots? Patrick
Hi Patrick,
Can you zip and private email the dxf file? Might be related to us now supporting draw views in addition to the model data.
Patrick, Fixed in next upload. The dimension arrow heads and other attributes were getting incorrected resized. Tim
Import/Export
