API
#1 Posted : Monday, March 12, 2007 7:04:50 PM(UTC)
API
Tim,
Can you clarify what versions of CU we need to have installed to be able to open older files. At one point CU would open everything back thru Vellum Solids I think. I have way to many CU folders in my Applications folder. Can you help?
Patrick
#2 Posted : Wednesday, March 14, 2007 9:06:34 PM(UTC)
API wrote:
Tim,
Patrick
Patrick,
CU1 & CU2 will open files all the way back to CADD Pro 1.0 which included the later versions of Vellum Solids thru Cobalt v6. CADD Pro was the first commerical release of the code stream (before Ashlar).
CU3, CU4 will only open up files from CU 1.0 and greater.
API
#3 Posted : Thursday, March 15, 2007 6:37:19 PM(UTC)
API
To clarify, since we own them all, we need to keep CU2 and CU4 in our Applications folder to be able to open everything.
thanks
Patrick
#4 Posted : Thursday, March 15, 2007 10:29:15 PM(UTC)
Yes that is correct.
