unique
#1 Posted : Tuesday, August 26, 2008 5:00:27 PM(UTC)
unique
Im having difficulty point editing on a curve....im sure it worked before:confused:
Create a control point curve and switch on points (or vica versa), for some reason I cannot select an individual point to edit or drag etc...anyone else seeing this ?
Edit> Just playin around and it only works by pressing shift whilst clicking directly on the point !!. Im sure one could window the point without shift previously...
#2 Posted : Tuesday, August 26, 2008 5:10:33 PM(UTC)
Hi, Paul
Can move individual point with no problem on 802 can you post a quick file that you cannot get to work.
#3 Posted : Tuesday, August 26, 2008 5:14:25 PM(UTC)
Hi Paul
It only works if you have midpoint snap checked if not you cannot move points here on 802
unique
#4 Posted : Tuesday, August 26, 2008 5:16:12 PM(UTC)
unique
Hi, Paul
Sorry Jason, you are right (no shift req'd just click on point)
I may be mistaken or thinking of Rhino but im sure I have used a demo that you could window a given point . Take for example two simple lines both connected at one end, by clicking on the points allows for two options when I would like to select both at the same time.....where has window gone ?
Thx
#5 Posted : Tuesday, August 26, 2008 5:19:31 PM(UTC)
Paul
It seems you can only window deep select two common points and move both together if snap to endpoint box is checked.
unique
#6 Posted : Tuesday, August 26, 2008 5:32:28 PM(UTC)
unique
Paul
Thx for you reply mate.
It's gettin late now and an early start awaits :(
Don't seem to get window selection to work here...see attached and advise comment..ill pick up again in the morning.
selpoi.zip (922kb) downloaded 5 time(s).
