chipmaker2
#1 Posted : Sunday, October 17, 2010 2:03:54 PM(UTC)
chipmaker2
Vc7 Xp
After projecting a curve to solid and splitting a face( with the ctrl button down) I can't move the face. With deep select I can color the face and I can extrude the face but no go on move the face with the move face tool?
Chuck
#2 Posted : Monday, October 18, 2010 12:26:57 AM(UTC)
I think you would need to ...
edit>change object type>surface
then it should work
chipmaker2
#3 Posted : Tuesday, October 19, 2010 8:33:52 PM(UTC)
chipmaker2
Thanks for reply JOL
The 3D face should work with this tool without a work around. For example in the same menu if I offset the face it will offset. If I draft the3 face it works also. Try to move or match the face and it's a no go. It's not consistent. If I Move or match the face after offsetting or drafting then it cooperates.
This is a good program and this like the primitives lost vertexs needs to be fixed asap.
Chuck
#4 Posted : Wednesday, October 20, 2010 1:50:12 AM(UTC)
hmm .. not sure - that face belongs to the solid
you need to drop to surfaces or offset (which copies) a surface by zero to get the surface you need
chipmaker2
#5 Posted : Wednesday, October 20, 2010 9:52:40 PM(UTC)
chipmaker2
then it should work, and then, hmm .. not sure - that face belongs to the solid
Try this. 1. Create a cube. 2. Split a face. 3 Deep select and color the face (just to prove to yourself the face is there). 4.Now window select the whole cube and at the bottom of the "Verify" drop down menu click "object count" and there will not be any surfaces but one solid and it's parts. Again after that if you wish, click on "check object" just below the "object count" at the bottom of the verify menu.
After doing all that it'll be obvious that the face is part of or as you say belongs to the solid.
Thanks for reply.
Chuck
