Originally Posted by: Steve.M I disagree.
Fine. You are welcome to your opinion.
Originally Posted by: Steve.M Not always- no. But sometimes, yes.
Originally Posted by: Steve.M It is now fixed, but shows your comment as incorrect.
In this case, as you quite rightly point out Steve, yes, I was incorrect. :)
Tim sometimes doesn't always answer questions we make to him. This is I suppose understandable in the circumstances isn't it? But with CAD software being so pricey these days one would expect offered software to be fairly bug free. As I said, I'm hoping to fork out for a seat of Shark very soon, and I (like you too?) want to be absolutely certain that I am not getting a turkey.
warmest regards,
Tom
Originally Posted by: ttrw You don't have to be impatient and rude Paul, but yes, you are right, and I was wrong- I was following your post but I had missed the type of polygon mode box. So I am sorry for that
I didn't mean to be rude, I just want to get my point across without the post/subject getting out of hand. Lets remember we are all the same side:D:D, that is we want the software to be good & user friendly!!
Originally Posted by: ttrw I'm very, very close to buying my own seat of Shark, so I too want to make sure that this stuff work before I shell out 900+ Hence trying to help retrace your steps.
Some of the basic commands like trim are still throwing up problems for me but I am sure Tim has them on his "to do list". The price is excellent IMO and will something I will buy next year (assuming it doesn't hike up).
Originally Posted by: Tim Olson >>Please post your geometry mate and lets see if its similar to the issues I >>face with trim Many thanks to Paul for the trimming examples and movies he has provided via the forum and private email! Tim
No problem at all Tim!! I just hope we see some of these resolved in the next patch so I can blow some smoke in your direction;)
Originally Posted by: Steve.M Here is the simple example. This is from VC 2d/3d 833
Good example and one I have sent to Tim some time ago. This issue is with B-Splines created by the Int. spline tool. If you try a Control point spline it works okay.....
A work around to OUR problem is to use the segment to curve tool which effectively "Splits" it up :(
Im glad you are finding these issues and commenting!
Originally Posted by: unique I didn't mean to be rude, I just want to get my point across without the post/subject getting out of hand. Lets remember we are all the same side, that is we want the software to be good & user friendly!!
Mate, that's cool :cool: :)
Bottom line is that CAD is hard to learn- Shark being no exception. It can be so deep at times :eek:
Originally Posted by: unique Good example and one I have sent to Tim some time ago. This issue is with B-Splines created by the Int. spline tool. If you try a Control point spline it works okay.....
Yes. Agreed. :)
Originally Posted by: unique This issue is with B-Splines created by the Int. spline tool. If you try a Control point spline it works okay.....
But that takes us back to the problems where the endpoints of a closed control point spline will move when the CP spline is trimmed and will no longer be connected correctly, which is another bug never fixed. The last post I made on this:-
http://forum.punchcad.com/showthread.php?t=2002 According to the logic of ttrw, that is not a bug because Tim did not answer.
- Steve
Steve,
Fixed....finally. As some folks mentioned, it had to do with trimming periodic curves (closed with same tangent).
It also fixes the one you mention in...
http://forum.punchcad.com/showthread.php?t=1469 Will post a qt movie showing this and a couple of other things it now does.
Many thanks all, your feedback was most appreciated.
Paul retesting some of your trim cases...
Hi Tim, Good to hear you have found and fixed that problem. Have you had any success with the problems with a CP closed spline where the end point connections lose angled position when trimmed? I have made posts before, but can post examples if required. Regards, - Steve
Originally Posted by: Steve.M Hi Tim, Good to hear you have found and fixed that problem. Have you had any success with the problems with a CP closed spline where the end point connections lose angled position when trimmed? I have made posts before, but can post examples if required. Regards, - Steve
Steve , please repost the example file and I will double check.
Hi Tim,
From VC 2d/3d build 833. Simple example.
Pic 01 shows CP closed splice, endpoints aligned. (file CPS trim)
Pic 02 show trimmed CP spline (file CPS trim2)
Pic 03 shows close up of now misaligned endpoints.
Regards,
- Steve
CPS trim.vc3
(13kb) downloaded 5 time(s). CPS trim2.vc3
(13kb) downloaded 5 time(s). Steve.M attached the following image(s):
(6kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Hi Steve,
This is fixed in the 834 build. I also changed the trim logic to preserve the start/end as one curve segment if through this point it is G2 continuous.
(Paul this will help with your offset ellipse trim issues as well)
http://www.csi-concepts.com/Demo/SharkFXV6/trimg2.mov Tim
Looks good Tim! Although I hope you haven't got the swine bug there- I here a tickly cough :eek:
Originally Posted by: Tim Olson Mint! When can I patch my VCPro to have these features ??:D:D
Originally Posted by: Tim Olson Hi Steve, This is fixed in the 834 build. I also changed the trim logic to preserve the start/end as one curve segment if through this point it is G2 continuous.
Looks good.
Good work and I look forward to testing(playing)
- Regards,
- Steve
