chipmaker2
#1 Posted : Tuesday, October 5, 2010 4:35:36 PM(UTC)
chipmaker2
When printing my drawing I get little crosses and circles at vertices.
The only layer turned on is the drawing layer. They are not there in the drawing but show up when I go to print layout.
Any ideas? See attached.
Chuck
Xp VC7
chipmaker2 attached the following image(s):
Circles and Crosses.jpg (60kb) downloaded 0 time(s).
#2 Posted : Wednesday, October 6, 2010 9:27:04 AM(UTC)
Chuck
Can you send me the ViaCAD file? I will look at.
chipmaker2
#3 Posted : Thursday, October 7, 2010 10:16:44 AM(UTC)
chipmaker2
Hi Tim, I had previously deleted all the other layers hoping it would help in layout. The problem persisted even though I tried using different PDF printers. See attached.
Thanks.
Chuck
Drive concept dwg.vc3 (100kb) downloaded 0 time(s).
chipmaker2
#4 Posted : Wednesday, October 20, 2010 9:59:54 PM(UTC)
chipmaker2
I now realize that the crosses and circles came into existence after projecting the 2D objects to a plane. I found that if I window selected the problem intersections or vertices and then hit the delete button the crosses and circles disappeared.
Chuck
