Crosses and circles (#3398)
When printing my drawing I get little crosses and circles at vertices.
The only layer turned on is the drawing layer. They are not there in the drawing but show up when I go to print layout.
Any ideas? See attached.
Chuck
Xp VC7
chipmaker2 attached the following image(s):
(60kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Chuck Can you send me the ViaCAD file? I will look at. Tim
Hi Tim, I had previously deleted all the other layers hoping it would help in layout. The problem persisted even though I tried using different PDF printers. See attached.
Thanks.
Chuck
Drive concept dwg.vc3
(100kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I now realize that the crosses and circles came into existence after projecting the 2D objects to a plane. I found that if I window selected the problem intersections or vertices and then hit the delete button the crosses and circles disappeared. Chuck
