2D Drafting
Centre Point Polygon (#2059)
Tim/Ryan, Does this tool work as expected?. I mean it's not consistent with the Solid Block one point which also needs a centre point which I feel works well. Creating a curve using this tool does not respect the X,Y,Z input?
Hi Paul Seems aok and consistent with the other 2D drawing tools such as Center Circle Point and Center Point Ellipse. Maybe you are looking for a new one point Polygon? Tim
Originally Posted by: Tim Olson Hi Paul Seems aok and consistent with the other 2D drawing tools such as Center Circle Point and Center Point Ellipse. Maybe you are looking for a new one point Polygon? Tim
Actually, no they are not consistent
Take the Center Point Ellipse (works fine btw) if you just Enter Major&Minor axis values and hit enter it bangs it on centre...as expected
Rectangle does not do that here Tim :(
Any news Tim, do you see this ?
Originally Posted by: unique Any news Tim, do you see this ?
Yes, looking into a fix. I was looking at the data entry window with something selected. The issue seems to be when you create a new polygon from the data entry window.
Originally Posted by: Tim Olson Yes, looking into a fix. I was looking at the data entry window with something selected. The issue seems to be when you create a new polygon from the data entry window. Tim
When you say polygon you are referring all types right because the data entry creation of slots, rounded rectangle, and rectangles are not preserving the type created as well as position if you use the data entry to define the geometry.
Yes, just fixed all the different types as well as the one mentioned by Paul. Thanks Tim
Thanks, Tim It makes the rounded rect. and slots tools much more effective.:cool: Jason
Originally Posted by: Tim Olson Yes, just fixed all the different types as well as the one mentioned by Paul. Thanks Tim
Hi Tim,
Did you fix up my request in 831 for the Polygon toolset (they seem fine now). However Rounded Rect & Slot does not :( ??
2D Drafting
