Recently tried to interact with a CNC shop. They use BobCad. I sent an exported DXF & DWG version of my parts. They reported being unable to open/view files. I suspect it is operator error on their end but was curious if anyone else has attempted this interaction?
Hi What what version of dwg/dxf did you export? Maybe they cannot open the version you exported? Regards Jason
good point. I'm pretty sure I sent R 2011. I asked what they preferred and was told "just send a PDF and we will quote from that." I really don't like that idea. Primarily, it allows for transcription errors. Secondly, I don't feel like dimensioning the thing. :rolleyes:
I just received email from another shop. They are also unable to process the files I sent (same files). They requested .igs or .stp versions. Part of my learning curve I guess. This is the first time I've tried to interact with these shops. I would hope that once the formats are established things will be smoother.
R2011 embeds acis/sat into the file. If they cannot process this data try r12 as it tessellates the data into something easier to import. Tim
Thanks Tim. It's Greek at this point but I will do it. :) Actually just hung up the phone with the machinist I'm working with. He clarified quite a bit of the expected interface/file format details. We are rolling along.
